Rubberised chasis coating
ronan1506
Hi All,
I'm currently addressing some surface rust on the rear chassis legs and engine bay area while the engine is out.
Renault used a very flexible tough sealer back in that area.
Any suggestions in good coatings to finish off these areas with?
I have ground off all rust and treated the areas with Wurth rust converter just in case I missed anything.
Not sure of what sealer to use next.
Thanks
Galvanising the rear subframe is a good option too, if you can find someone to attend to that.
The Ph1 wasn’t blessed with a decent quality of underseal in certain areas. SGM has posted up a few case histories of severe rust worm on his Facebook pages in the past.
On my other cards that are in for resto, I have removed the surface rust (knotted grinder wheels are very effective). Treat it with Bilt Hamber Hydrate 80, then Bonda Rust Primer, then I went for Gravitex on top which gives a great, and tough durable finish.
Thanks for all the advice
Using an air belt sander for some areas which is great too.
Using Wurth rust converter over the Areas cleaned .
Check the bungs around the rear part of the sills . Found water pooling in mine. Think sg had a video up of that before. Replacing the bottom sheet of the sill box section on mine anyways but it's a prime area to hold water and rust.
[album]23379[/album]
[album]23380[/album]
