Oldskoolbaby":305y6vgj said:
Arno, from the day of saying I want some how long will it take the a set to arrive at my door? I have just aquired a new car that will need a set of after market coilovers.
However, I always stick to the saying of "all that glistens isn't always gold" so I need to know a few things.
1. How will they compare to KW v3s in terms of performance, longevity, guarantees and customer support with setting up?
2. I also need to see some feed back from people who have used them on track/competition.
3. I'll need to know exact price. If they are very high, please state why I should buy RC Centre dampers over a similar damper with the legendary Oilins stcker on.
Thanks
1.
RSC can't be compared with all the 2 tubes systems. The comparson is better with other monotube systems like H&R, KW Comp. or Öhlins.
The valve technology is similar Öhlins, but the mechanical RSC valve automatic works faster. The piston diameter is also very big (about 47mm), than the most others.
Very high damper performance, very fast, calm, unspectacular and sovereign.
Since i make these kits, I've never had a broken damper. Over the guarantee period of 2 years.
Set up with this damper technology and adjusting with the combinated bumb/rebound knob is very easy. With this system, you're never wrong.
And I am always available to my customers. Faster than the big brands.
Here the RSC data sheet in short understandable words:
https://www.rscenter.ch/wp-content/uplo ... 017-EN.pdf
2. I have a lot of feedback from road&track / trackday drivers, I collect them all here:
https://www.rscenter.ch/en/products/rsc ... feedbacks/
3. The price depends on the model and equipment. Almost everything is possible. Argumentation see points 1 and 2.
