Ewan
I am swapping the engine in my R26 with a RS250 unit retaining the R26 ECU and loom. Should clarify at this point that 'I' means 'I am paying Rentec in Edinburgh'
Ok, so we are keeping the R26 ECU and loom and swapping in the RS250 engine with turbo and the mk3 inlet manifold, fuel rail and injectors.
I know that we should be able to run the RS250 engine with the existing mk2 fuel pump, although it won't offer the rising rate fuel pressure. The question is can we fit the mk3 fuel pump to my car and take advantage of the rising rate rail with the mk2 ECU and loom without a massive headache?
