Megane RS250 BUCKET SEATS (AIRBAG LIGHTS)
T&biskits
I have just fitted Recaro Pole Positions in my car. Now i have the dash lit up with Airbag light, Heated seat light & spanner. From what i am led to believe, i either need resistors or Clip to erase the lights on the dash. Could anyone shine some light on what the safest way is to remove these lights. I have no idea about resistors or electrics, & i would only use my local Reno dealer to buy screenwash from. Any help would be appreciated.:dy:
Went to a local car workshop, who sucked alot of air thru his teeth, giving me the`airbags, removal, danger!`. So i gave up with them. Pure are a bit too far. Trouble is around Somerset, there aren`t alot of specialists. The ones that are supposedly `specialists`, i try to avoid, due to previous encounters.
Surprised entered into this modification without thinking through, have you retained the factory belts? are seats correctly fitted? there are several circuits that need satisfying when removing factory seat inc belt warning buzzer, tilt switch and airbag activation switch.
Numerous people have fitted buckets to a Mk3, i`m just asking which route they have taken to remove the dash lights.Std belts are retained & the seats are facing in the right direction. Due to the South west of England having very limited `specialists` that i would trust not to f**k it up.:bm:
I can prob fix the dash lights issue, first need to know what you've done with multi pin connector under seat both on seat side and car side as its there that he mods need to be made, have you retained the buzzer, and what did you do with the tilt switch from factory seat as that's prob what's giving the spanner dash light
Both multi pins are tucked under the carpet, all i have done is unplug the yellow multi & remove the wiring plug from the seat belt buckles, whatever is left is still attached to the std seat.
