rolling road trophy
mick.harris
came accross this trophy on the rolling road,
not sure if it's already on the forum
sounds like mine when I take it to the shops !!!
I knew I shouldn't have tried to post something technical Matt,
if you type 'clio v6' on you tube,
then filter ' this month,
it's there under renault clio v6 manufacturured by chipfactory motorsport,
be a hero matt and find it ! it's yellow,
sorry to everyone,
it there under renault clio v6 manufacturured by chipfactory motorsport,
sorry to everyone,
No worries think Andy has posted it below.
Cheers Mick :approve:
We need a company like Borg Brothers to make us a an inlet manifold so we can use E36 M3 ITB's or similar. I think you need a Mr Patchalls exhaust, a Trophy flywheel and race cams to sound and act like that. ITB's alone will sound out of this world though........uhmmm one day.
That sounds awesome :salut:
Did Fred ever get the ITB's fitted?
Is the inlet manifold the major problem then Brett? As in you just can't buy one to fit?
Not sure what the issue is to be honest. Fly by wire is easily sorted with an Emerald K6 ecu and their are plenty of fabrication shops that would build you new inlets. I'd personaly cut down and modify a ph2 manifold though.
