Rolling road results.
Ali
Right mines booked in for the 3rd of sept, going up against a friends DC5 so it should be semi close.
i think i read before no ph2 Vee has got close to 255bhp ATF...
Mines got an aftermarket exhaust and it's remapped too...should add 5 or so i'd think.
Anybody else had results?
heres mine befor and after a qs sport box fitted, black lines the befor....
-from stadard
(using trw1s correction equation)
at the wheels 202.8BHP @ 103mph. 6561RPM
correction (202.8+10)/.88 = **241.81 BHP**
276.27 Nm (204 lbs/ ft) @ 4811RPM
-after quicksilver sport and green panel filter
at the wheels 210.2 @ 108mph. 6988RPM
correction (210.2+10)/.88 = **250.22 BHP**
270.86 Nm (200 lbs/ ft) @ 5127RPM
noting the befor using 40mm profile tires abd the after using 45mm profiles, this constitutes to the higer rev figure i think had i had the lower profiles the second time the fiqures would have been more accurate in terms of comparison.... that remonds me i must get back on the rollers.....
Cheers guys! Will let you know the results! If it runs less than 240, i'll lie and say it ran 242.1bhp just to beat the slow brown vee! ;)
