A
administrator
Its with regret I have to advertise Morph ( so called due to numberplate ) for sale.
The reason is that the powers that say Yes have said Yes to me getting either a clio 197 , or a f1 230. Its my choice ..
I need to 21t to make way as I need a deposit for the car.
I can tell you this about the car.
It a Phase 2 shell
It has phase 1 back wheels
It has phase 1 hydraulics
It has a phase 3 engine with a dizzy converison
FMIC
Scorpion Exhaust
Induction Kit
Taxed until April , tested until July.
No major rust , rear arches are fine , slight surface bubbling on rear doors , 5p piece size.
New track rod end.
4 tyres with good tread
New clutch less than 4k ago
Brand new water pump fitted 2 months ago
the car has 148k on the clock , but this is largly irrelevant , as I have had lots of parts changed - and all oils change frequently.
You have three levels of purchasing my car
£700 - this will get the car in the above trim
£750 - as above with a turbo timer , setup , ready to go
£900 - as above with a freshly rebuilt t34 , cossie housing , and cosworth downpipe and a dash 31 acutator
You are buying a daily driver 21t here. Used it for 2.5 years with only two major faults , both being rectified - alternator , and belts snapping.
Now with centercaps ..
as seen here !
come and view her - I am based in Doncaster.
drop me a line on 0770 6809304
It a Phase 2 shell
FMIC
Scorpion Exhaust
Induction Kit
New track rod end.
as seen here !
