Classic Renault 21 electric window switches
My passenger window was acting up- turned out both the switches has bad contact points.
Prise this rocker off carefully to remove the top of the switch
Remove this yellow bulb holder. It pulls out. You can replace the little bulb in here if the switch lighting doesnt work.
Prise out the white things CAREFULLY, making a note of orientation and where the lugs at the side clip in
Lift out the metal springs on the outside of the switch. These pull out with a little bit of a tug.
See those copper plates at the bottom? Make a note of how they sit/orientation and then fish them out. Theyre not fastened in they'll come out, if a bit fiddly. Clean the small contact points on both sides, one is square and one is rounded.
Rebuild the switch, just put everything back where it came from in the reverse of the above sequence.
