It's a two person job. Or one with support for the door.
First check which type of door pin, then order the correct one's from Renault. Also order the copper bushes, you need 4 per door.
Open the door, undo the check strap, two 13mm(?) bolts.
Then drive the door pins out using a suitable drift, screwdriver - bar with a dimple in the middle.
Support the door and remove the pins. Remove the door from the hinge.
Drive out the copper bushes, don't worry about them you have new ones.
Grease the hinge, and fit the new bushes.
Re grease, and ease the door back on the hinge.
Best bet is to line up both hinges and give it a good shove.
Once its lined up, that can take s few goes, drive the new pins in.
Re attach the check strap.
Job done.:applouse:
---------- Post added at 08
6 PM ---------- Previous post was at 08
4 PM ----------
Dam you Sibley, beat me to it.
