Hi all,
perhaps useful info for overhaul / inspect the rear calipers. It's more or less the same seal kit as used for the citroen xm?, but these seals are designed for use with brakefluid instead of LHM fluid.
Repair kit pistons maker Budweg
The correct seals for the handbrake lever mechanism I haven't found. :salut:
