TIM, come down and see me and we can get it plugged in to my scanner, will test each abs sensor seperately whilst driving the car. what exactly is your prob and if you have a problem does the speedo still work.timv6":3u2asxzi said:Hi Need to check/test the spped rate sensors on the car...
This is done firstly by freeing the wheels of the ground and then spinning them one by one.
However im not certain how you physically "test" the sensor. Is it with a voltage test or.....
Any help much appreciated..
Thanks Tim
