Random N.O.S genuine parts.
sarah
Here is a random selection of genuine new old stock renault parts,not much to do with renault turbos but if there are any parts of interest,contact me for prices & also if you need any more info on any particular part ,let me know and I'll do my best to look them up on the microfiche.
Tel:07919936380
Jack. :wink:
77 01 383 267-scenic alarm
77 01 387 803-R9 Biarritz Decal kit
77 00 669 405-ign module 21+savanna
77 01 349 471-distributer R4
77 01 201 226-Brake shoes R5
77 01 016 858-Light lens R6-Rodeo
77 01 019 264-Air filter R5
77 00 787 641-Wheel hub/baring R25 X2
77 01 366 503-Lens rear Mk1 5 ---------------------SOLD
77 01 203 919-R/brake pad set R19 16V
77 00 701 834-m/cylender Traffic
60 25 071 209-Screen kit Espace
60 25 170 034-Fuel gauge Espace
77 01 200 283-Bendix caliper kit R16
77 01 460 690-Valves C1E
77 01 352 052 Alt Traffic/Master
77 01 466 803-Baring Safrane
77 01 469 411-Gater kit Megane
82 00 048 709-Door loom Scenic
77 01 038 420-Stalk Laguna
77 01 035 469-Fog lamp Clio 1
50 00 815 440-Cam belt Megane
77 01 460 247-Water pump 20/30
77 00 680 761-Speedo cable R5 mk1
77 01 033 848-Speedo cable R18
77 00 626 368-Speedo cable R14
77 01 202 046-Caliper R25
77 00 789 285-Arm rest R25
77 01 202 786-Piston caliper n/s/r R20/30
77 01 458 260-Ball joint 20/30 x3
77 00 533 443-Eng mount Mk1 R5 x2
77 01 022 769-Mirror glass 20/30
77 01 203 893-Lock set Safrane -------------SOLD
77 01 034 811-Tacho Clio
77 01 465 497-Valves 21/Safrane
77 00 115 194-Fuel pipe metal Laguna
77 01 462 692-Ball joint Master
77 00 641 764-s/column with u/v joint R14
77 01 462 019-Front wheel baring kit R14
82 00 061 281-Inj computer Clio 2
77 01 023 560 Speedo/odometer R14
77 00 754 833-Alt 70amp- 21/Saf/Esp/tra/master ------------- SOLD
77 01 348 350-Brake compensator 18/Fuego
77 00 308 589-Shock abs n/s/r Kangoo
77 00 700 909-Shock abs rear Traffic
50 00 389 987-Shock abs rear Master x2
77 00 793 074-Shock abs rear R19 x2
77 01 032 225-Heater matrix R25
77 01 038 620-Indicator RHF Megane
50 01 000 878-Air filter R21/20/30/Esp/Jeep
77 00 725 817-Rear shock R18
77 01 461 140-Track rod &end R14 x2
77 01 469 502-Track rod arm Megane
77 00 780 890-Plate s/absorber R19
77 01 461 331-Ball joint R18
77 01 032 328-Tacho R19
77 00 782 266-Front sus/spring R19 x2
77 01 034 659-Wiper mech Clio 1
Hi - what do you want for the 77 01 348 350-Brake compensator 18/Fuego and 77 00 787 641-Wheel hub/baring R25 X2 (which bearings, which series?) and maybe 77 01 032 225-Heater matrix R25
Hi-not a very good service!as I only just noticed your reply!! I still have these parts,I will look up the hubs and let you know which model they will fit.
All the best.
Jack.
Hi,
77 00 787 641-Wheel hub/bearing R25 will fit V6injection models:B29A,B29F,B293,B298.
77 01 348 350-Brake compensator 18/Fuego-?15
77 01 032 225-Heater matrix R25 -?10
77 00 787 641-Wheel hub/bearing X2-?25 the paire.
+the cost of postage.
Let me know.
All the best
Jack.
