cbx6_79
Hi all
I'm new to the forum, and for the fun of it I thought I could share some pictures from my old R8G Turbo project.
I am from Norway, and since the mid 70's been interested in the R8 Gordini. Have owned a few 1135's and at the early 1980 I thought it would be great to try a turbo conversion.
At that time the prices and availability of cars/parts were very different from today. I had a stock 812 engine and got new 7:1 compression pistons from Venolia in the US. Cylinder head was fitted with larger valves, but camshaft stock atmo.
I bought a set of new Dellorto DHLA, that was designed to allow boost pressure. They fitted directly to the stock inlet manifolds for the Webers. Home made exhaust manifold and a Rotomaster tubo on the top. Wastegate valve was adjusted to 0.8 bar.
The stock radiator was moved to the front of the car, and an intercooler took its original place in the engine compartment. Had the engine dyno tested in Sweeden, and output before any further adjustment was 147 bhp. Stock displacement of 1255 ccm.
Engine was paired with a 353-13 gearbox. The car was actually pretty fun to drive, and I had it as a "daily driver" for a couple of years. Sold it to a mate, but 40 years later I was able to buy it back from him. MOT inspection did not exist at the time I built the car, but now that became an issue.
At first inspection I removed all the Turbo stuff, and installed it back in again after approval. But found out this was a bit too much work to do at every MOT, and now the car is rebuilt to stock engine configuration and wil stay like that. The only thing that is kept from the 80's is the small body modifications.
