R5 t2 turbo exhaust housing
aye, common problem though, especially the age most afre now. I wish you luck in finding one.
You could have yours welded but its tricky welding cast as you probably know then will have to have the wastegate hole machined flat again.
you can get them out though. Put the housing in the freezer for a day or 2, pull it out take it somewhere get them to weld nuts to the broke studs, they'll come out easily after the freezer treatment. I do that for bleed nipples etc
