R5 F7P conversion - wireing loom changes
G
Guest
hello. i want to change the engine on my R5 with one f7p engine.
facts: i changed the oil pressure sensor from the back of the engine with the oil feed for the turbo.
the oil pressure light sensor from the front was changed with the R5 GTT oil pressure sensor (it has double function: light and pressure 2in1).
the question is .. maybe with pictures....
the f7p engine wire loom has got 2 connectors and the R5 has got only 1.
which wires go where...
thanks in advance
need to speak to winston on this one...but need loads more info really..
Im clueless lol
Im going to use the clio car loom... so i get the gauges, I will just have to put the loom on a diet :P
White plug connector i believe is only used for fuel pump connections.
You only need to tap 1 wire from that (+12v to pump), tehn concentrate on finding what goes where on the big brown plug
i've seen a r5 with an f7p engine which had the fuel pump where the battery usually stays. is the pump so good to suck the fuel from the back?
