For Sale R21 turbo body sections
Haz
Thinking of cutting up simon's accident damaged tungy ph1 soon if anyone is in need of sections. Nsf bump.
If you do cut it up I would like both the front seat rear floor bar that goes between the tunnel & inner sill please.
I have tried pulling and beating it, I knew it wanted the full corner inc leg replacing but I think the whole front is out of shape. It's probably worth putting on a jog and fixing in a few years when prices increase but the amount of work it needs it's probably best just keeping others on the road.
I'll check areas over the weekend and get some pictures. Osr arch has been patched if I recall, doors aren't to bad, where bonnet catches is bent but just that bkt.
Floor is ok I think.
I just didn't want to chop sections only to not take enough that is needed.
Will probably be within the next few weeks.
This has taken a while to get round to doing!
@Red21 and @DaveL485 are you still requiring bits? Can you draw on a pic where you would like the cuts.
Turrets and osf corner removed so far.
Looking at the car is it possible to cut both bars out as a single plate giving about an inch extra beyond the bars please
Yes, I'll have to check condition though. How soon do you need them? The earliest I could check is next weekend.
The spare rear doors I have require work, straight but rusty, probably only any use when good ones aren't available.
Hi Haz
I am pretty new to this site and somehow I haven't seen your last message about the doors - to be honest mate looking at the pictures I am not sure if they are much better than the doors that I have on the car already but thanks for the reply and a chance to have a look at the pictures of the doors
That's ok. Most doors are like that these days, the rubber trim traps the water, rotting them and the arch together.
