R19 16v parts
Thinking about it, I've got the inner lower one as well.
How much would you like for those parts ?
Don't suppose you have the fixing bolts for the upper cambelt cover as well, I'm converting from a clio engine & pretty sure they are different ??
Need to get this 19 back on the road !
ta
Steve
erm, the little torx button head screws? Might have some in one of my random nuts and bolts tubs.
edit: sorry, just realised you said top cover mounting bolts. Those are just normal 13mm bolts at the top and 10mm at the bottom (if you bother fitting them)
As for price I'll have to weigh the manifold and suss out postage cost, I'll let you know.
Do you need any of the breather pipework, cold start injector etc. to go with the manifold?
May as well if you have it, not sure if the clio stuff is alot different.
Let me know how much, I have an ICV.
Isn't the alternator bracket etc different on the 19 too, or am I imagining it?
I deffo have the 'cradle' for the alt, will check I still have the thermostat housing, pretty sure I kept that as well as the engine mounts..
EDIT, yes still have the thermostat housing.
