Quadra HB cable adjustment...
S
sonof
Is there an easy way to do it?
Or do I HAVE to drop the exhaust and the center UJ joint on the prop to get at it properly?
Cheers,
Pat :icon_biggrin:
you NEED patients HAHA, 11mm and ..mm cant remember if its 12mm or 13mm..
Standard length spanners allow for 1/8 turn at a time..LONG..
alternatively you can get stubby spanners, or buy cheap and chop them in half..
Not a lot of room and plenty of swearing will be needed, as always
good luck, I've done it once, and I'm NEVER doing it again...
cheers dan, i may just buy some cheap spanners and chop em down then :icon_smile:
Thats what I did, chopped one right down to about 3 inches.
It is a bit of a cock, but doable if you make sure the exhaust is cold lol
