power steering fluid
under the engine cover in the far left hand corner (when you're facing it nearest to the boot) - tucked under the cover.
You can't see it as the cam cover is in the way you have to take all the engine covers off to get a level....I was looking the other week thought I would have a quick look spent 10 minutes looking for it then finally gave in looked at the manual tried to cheat by using a mirror gave up and 15 minutes later covers off only to find level was fine!!!
Good luck!
