Phase 1 Front bumper lower rubber rubbing strip
Ren5Clio
Hi everyone. I'm looking for a close up picture & sizes of an original phase 1 V6 rubber rubbing strip that screws to the underneath of the front bumper lip. I know they are NLA from Renault so am looking for a similar section shape rubber strip that i can source from a rubber extrusion company. Is the original Renault item as simple as an "L" section shape strip ? All pictures & info is appreciated. Many thanks, Jules.
Some photos I had found of the OEM phase 1 . It’s just an L shape.
There’s a Skoda Fabia one which fits and is off the shelf. It’s ever so slightly larger than OEM and it’s harder rather than the soft rubber, but you would do well to notice it’s difference unless you have two side by side!
The Skoda one is £13 from memory.
Ahh that's great info, many thanks. [smilie=yay.gif] Do you know what exact model of Skoda Fabia ? If i go to a Skoda dealer they will want VIN No or Reg No. Also just for reference what are the section dimensions & thickness of the OEM Phase1 item you have there ?
Ok no problem. Thanks for the Skoda link. I might try and match the section shape & sizes from your pictures of the Renault OEM one but failing that i have the Skoda one as an option. Many thanks for your help. Kind regards, Jules.
