Ph1 track rod ends
dal.a
Can anyone point me in the right direction for replacements please.
I changed my front discs yesterday and they don’t look too good.
Also when looking at previous MOTs in 2016 there was an advisory or Steering Arms having play, I haven’t changed them and they have not been picked up since.
If it's track rod ends you need
RH rod end 77 01 474 493
LH rod end 77 01 474 492
Search ebay with the numbers......
if it's the inner rack joints then you have a bigger problem replacing them.
Thanks, I’ll try and have a better look but will probably replace the outers anyway as they look poor.
I don’t want to know about the inners by the sounds of it.
The outers are the same as a 172/182 so easy to source. In fact the rack arms are too IIRC, they're either 1)an absolute fuckwad to change or 2)a piece of piss to change, depending on if you have the right, specific tool to do it.
So a 10 year old Halfords socket set ain’t going to cut it then :)
