Hi guys
The oil pressure gauge doesn't works. I checked the instrument cluster and I found that the resistor of the " motherboard" of the oil pressure gauge was broken.
Does anyone knows the resistance value of it? Can anyone measure?
Best regards
I am pretty sure that is a 1W Resistor. Green (5) Brown (1) Multiplier Gold (0.1) Tolerance Gold +-5% so a 51x.1 = 5.1Ohm next stop Farnell or similar.
The Yellow component next to it also looks to have been fried with the heat from it, if you can check for a dead short on that circuit.
