PAS PUMP PIPES
SimonLM
Does any one have any alternatives to the stock pipes as I am sick of them sweeting. High preasure silicon? maybe.
Loudman - you could take the option I've gone for which is to remove existing PAS pump and go for an electric one mounted at the front of the car.
106/VTR/VTS will do the job and can be found on eBay for sensible money. The other alternative is a pump from a Merc A Class.
No Not GAY just my poor spelling.
I ment Sweating.
I dont really want to put an electric pump on although I know there good had one on girlfriends 1.9d clio.
I just want to replace the pipes while I have the engine out.
I did use them once to replace a hose on a cheery picker we used to run. Good job but as you say not cheep.
There not broken but they breath and then drip onto the subframe, Ive had them replace once by renault under warenty. But it started again very quickly and I just want to sort it for good while I have the engine out.
