I'll do the math on the txi conversion .The spare rims need a refurb on the two fronts and also smaller rubber on the rears .It might work out cheaper to get 5 stud wheels .
Txi hub conversion is expensive, two rear hubs at around ?100 each new and then two front hubs which I think are similar money maybe slightly less either way not worth converting to 4 stud unless there are some amazing wheels which you can't get in 5 stud.
Looking to stick standards back on mine. Need some standard wheel bolts first though as these have a cap head type bolt in. They'd come with spacers and they only rub when I have had people in the rear and the boot fully loaded. They're 18'' by the way.
I have had 17's on my car but have recently gone back to 15's for the much smoother ride, with the 17's the slightest bump was felt smashing through your spine.
