A
Anonymous
Anyone know where I can get these coolers? If not, I will have to et some custom made.
Thanks
Thanks
hog":bhmxn0q9 said:Hi Klio, I just think that an air exchanger type cooler maybe better on a road car but you could probably plumb the water cooled type into your car.
What water temps / engine oil temps are you reading in the summer in HK?
hog":13hjvib6 said:100 centi?
You really want water temps of not more than 88-90C and if your oil temps go above 100C then you are cooking the oil and at least need to run synthetics.
Have you thought about fitting an electric water circ pump and reprogramming the cut-in temps on the rad and engine bay fans?
hog":hsjacwjl said:Take out the thermostat from the housing and take it along to a local machine shop or garage and ask them to make a restrictor plate the same sized as the stat without the opening valve in the middle. A piece of brass plate is easiest to work with. If you have any contacts with either a CAT or GM diesel dealer then ask them, 'cos I'm sure they do it to their older units out there.
Water wetter is an additive that reduces the ph level in your coolant (please don't tell me you are running without an inhibitor in your coolant?) Red Line and STP are popular manufacturers.
I can give you a really good explanation but I'm not sure that you are upto this level of engineering or chemistry!
You can read more on the web.
Nalcool is one of the best but not available in small quantities.
