Oil capacity Phase 2 clio
Including filter about 5.5 litres
Sorry put engine capacity down.
Gear box oil you have to get from Renault.
PK6 Gearbox = 2.2 litres
ETL 8275, 75W 80W
Think you will find that in actual fact slightly less.
Thanks for the info' on the amount in the box since it is not a "level plug overfill" type.
I think that Renault gear oil is only semi synthetic. I wanted to use Lucas 75/90 fully synthetic stuff, and would assume it ok? even with the slight difference in grades? I used this in my front and rear diff's plus getrag box in the Skyline.
Nik
