new sump
G
Guest
i've smashed a hole out of my sump, so need a new one, whats involved with the fitting.
also how hard is it to fit a new subframe on my drive? engine out or no?
Its a pain in the arse with a valver box, as the box has bolts through the sump. the subby is easy, the engine hangs, so no need to remove the engine, just the down pipe and dog bone mount, pas pipes, rad, and pinch bolt from the column.
i'm dropping the subframe anyway so can i get the sump out when i've done this? taking the engine out isn't really an option so i'm trying to find a way around this?
