My new turbo install
Mike T
Car not yet mapped or running boost control so limited to 6psi and running supercharger map
1st stats (from the logger not a stopwatch)
0-60 at 54% throttle and only 5psi of boost (18psi available when mapped)
4.76 seconds
0-100 at peak of 60% throttle in third 10.2 seconds
0-30 1.9 without LC activated (bit smoky on the tyre front at 77% wheelslip!)
Probably 325 bhp and 300lbft give or take - target 500 and 500!!???
This is the mutts and the best way to spend Sundays!
Sent Tim the data files for him to post up if he can!
Standard Mk1 with it's super low 1st gear and full traction does 0-30 in 1.9secs!! Neck and Neck up 'til then! :D
mapping then video - Tim may be over in 10 days time
and my son is a lightweight and apart from being faster than me thats the only advantage he has!
If you experience any aero-related issues as a result of this turbo-charging buffoonery, I have an old ironing-board you could use as a rear wing.
I Could also thrown in a free Renault sticker to make it look authentic as a deal clincher?
Carbon fibre ironing board already in place.........
