James5
Well I recently purchased a low mileage really good condition meg 225 with a lack of power and smoking issue, after some initial investigations this turned out to be Nil compression on cylinder 3 so instead of rebuilding the original engine I bit the bullet and decided to purchase another engine. I managed to get hold of a lower mileage engine from a car that had sustained a some accident damage (rear ender) and had belts done within the last 2 years (so a bonus) was also a little lower mileage than the original.
The 225 is nothing special just a bog standard 225 3 door model but is really clean inside and out, I have so far replaced all coil packs (Genuine Renault), injector's (Genuine Renault one's), New filter's again genuine Renault, fitted a de-cat decided to give the ebay special a go, and am about to get the car mapped once finished.
To do list-
To do list-
- Driver side driveshaft fit,
- Passenger side driveshaft fit,
- Work out how the ABS sensor's fit (didn't realise the cables had fallen out both sides),
- Replace drivers side drop links,
- Replace passenger side drop links,
- Re-attach swivel hubs both sides (lower section to wishbones 3 bolts each side),
- Disc's callipers,
- Gearbox oil,
- Bleed hydraulic clutch,
- Source replacement coil pack plugs for loom as couple damaged,
- Start car and hope for best
