Wicked Neo
I visit now and then...
Well just filled up with petrol and drove off onto the main road when the oil light came on.
So I pulled over to the side of the road and shut the engine off, popped the bonnet and checked the dip stick....nothing on it!
Strange as only that morning I had carried out all the routine checks on it and the dip stick was showing just under max.
Looked back up the road and there was loads of oil on the road behind me though, starting just after I had pulled out of the garage.
Checked under the car and oil was just dripping off the underside, was also all over the front splitter right about where the oil cooler sits just behind the bumper..
So called out the AA and was told it was suspected oil cooler failure, it was possibly punctured, nothing they could do on the side of the road and ordered up a recovery truck.
Full marks to the AA for how quick they turned up, it was 10
0pm when I called them and the first guy was with me in 25 minutes, the recovery truck was another 30 minutes from when they was called :smthumbup
So today I started to take the car apart to check the oil cooler, once i had got the inner wheel arch plastic and brake duct plastic off, it was obvious why the car had dumped all its oil
one of the oil lines to the oil cooler had come away from the oil filter housing and this is why
Not sure how that could have happened? any ideas?
At least its a cheap fix.
