Ok, I've had a misfire since last Wednesday. It started at the end of a 40 mile trip. Initially at 80mph, it felt like I'd dropped a cylinder. I pulled over, and it was firing on all 6. As I pulled off 1st gear and 2nd felt fine, but the problem became more apparent with each gear change, as the engine was loaded up more.
For example, if I dive at 50mph in 6th gear, and put my foot down, the car will struggle to gain any speed at all. It make no difference if the engine is hot or cold. The only thing tht has changed, is the mis fire isn't as noticable as at first. But is still present, and my fuel consumption has increased slightly.
Its been on the computer this evening, and no faults found. [smilie=icon_cry.gif] [smilie=icon_eek.gif] [smilie=icon_cry.gif] :rollseyes:
I currently have the engine covers removed for access. The best plan I can come up with so far is to buy 3 new spark plugs, and 3 new coils, fit to front, then rear, to prove out possibility of faulty plug/coil. Not what I wanted to do, but cant think of any better idea. (it has just had new plugs fitted)
Anyone got any ideas?
