megane f7r lumpy idle , stalling , missfire , overfuelling
hairymel
97 megane coupe 2.0 16v f7r
sudden onset problem
stalls when coming to rest and changing gear.
at startup will not idle without throttle.
will idle rough then revs will drop to 0
after 30/40 seconds will keep running but is very lumpy and revs fluctuate between 1000 and <500
missfire?lumpy running below 2.5 revs but clears at higher revs
seems to be running rich at idle
changed coil pack for s/h - no change
changed plugs - no change old plugs were all black and sooty
cleaned icv - no change
with stepper motor removed and valve manually activated the rough idle and missfire is still present
changed icv for s/h - no change
cleaned crank/flywheel sensor (tdc?) - no change
cleaned camshaft sensor - no change
injector cleaner - bit of improvement in lumpyness/drivability when warm
re terminated the 3 wires at front bottom of block - (all onto the stud earthing point as the torx bolt was not removable) no change
cleaned throttle body - idles a bit better but still really rough
blocked off egr valve - no change
i have also used several cans od wd40 on all the hoses/pipes but no joy
have ddt2000 and xr25 with vagcom lead but am struggling to understand them!
no faults registered - injectors seem to be firing with long duration at idle (9000ms?) and duration drops with revs (3-4000ms?)
temp sensors seem to be outputting ok values
map semsor seems to be doing something
lamda seems to be outputing a signal
any pointers would be most appreciated :-)
thanks
mel
I'd still look at the temp senders.
Unplug the coolant sensor (stat housing, should be green)
The fan may or may not come on (depends on loom etc) and see how it runs.
Also are you watching live data or data from a mulitmeter?
Also it will be 9m's not 9000.
9 is still on the high side, cold start on an SFI will be up around 7 max and even then it would have to be a very cold start for that.
hi Chris
i have a black hole where my decimal points should live, thats why i put a ? :lol:
data is live from ddt2000/vagcom but my french is stored in the same place as decimals:oops:
i have tried pulling various sensors in a random fashion but as soon as it stops raining i will have a look 8)
thanks
mel
green sensor appears to be the dash temp guage sender
white sensor on thermostat housing disconect gives coolant temp sensor fault code and shows temp of -40c in ddt2000
car already warm
no difference in running, no fan
reconnected sensor and cleared the error
just dies without throttle for 20 secs after start then will stay running afterwards.
L'avance à l'allumage (ignition advance) fluctuates fairly quickly between 2 and 22 at idle but with higher revs settles around 35ish
when the idle is more stable the injectors show 4ish ms but as it falters it increases to a maximum of 9 or 10 ms
i'm much happier with spanners :(
thanks
mel
yeah forgetting the age of this, the later cars had all the functions in one sender.
The cts shouldn't default to -40, it should show fully warmed up engine. With it plugged in do you get live data off it? What time base? Is it increasing linearly or dropping out?
Ignition sounds fine, at idle though it should only fluctuate maybe every couple of seconds from a low like 2 to 22, it advances until knock is detected backs off then repeats. At higher speeds it obviously has a shorter window to alter so it stabilises out when being read.
Whats the lambda doing? 4 ish is correct, when it goes to 9 or 10 its doubling the injection duration which means it thinks its either just gone freezing cold (like -40) or the lambda is is saying its running lean.
data is in real time as far as i can see
temp looks as i wouyld expect with it rising fairly evenly from cold to mid 80's
advance cycles in <1sec
dump of lambda, advance, inj duration and rpm from startup below
started on throttle to prevent stall , then left to idle, then 3000 revs then back to idle
learning something new every day:D
thanks
mel
lambda data looks funny, but that may be the time base its set to, which I can't see.
Does the speedo work ok?
time base? no comprehende':(
duration of capture was about 100 seconds
speedo works ok , not sure about trip comp as the stalk is non functional:roll:
i liked the lambda at 3k revs but i have no idea what im supposed to be seeing:lol:
pi$$ing down again this end of our sceptered isle so i will call it a day!
now that i have discovered data capture is there anything you think i should look at?
thanks for your help
mel
if that entire capture is over 100 seconds then the lambda isn't switching properly.
It switches fine when the revs are raised, start it hold the revs up around 3k rpm for a few minutes and then let it drop to idle, see if the lambda switches.
Rain boohoo its snowing here :lol:
its always grim up north:lol:
will post again after i have done as you suggest
have a hot toddy on me;)
thanks
mel
Haven't read any of the thread but from the symptoms check your map sensor and associated pipework and wiring.
