Looking for parts: Drive shaft boot / exhaust mount
Adrian
Could you anyone help me with the following parts?
I need a drive shaft boot as marked below. Left side inner boot.
Dialogys mentions only complete shafts in the past. How did anyone solve this?
Naamloos22 AJT
I need new rubber mounts on my exhaust backbox. Where can I source these?
Renault does not deliver them anymore I was just told on the phone.
Naamloos1 AJT
I just did the outer boot on my O/S shaft and I used a standard universal stretch boot. It was a perfect fit out of the box, readily available and inexpensive. I keep a couple in stock in my garage :)
EDIT, after having actually paid attention to your pic the inner boot pictured there has a bearing pressed in the end - has your boot split or is the bearing weeping oil? If you unbolt the flange to the gearbox the gearbox oil will empty on the floor so drain it first. I send these to a recon place near me to be replaced, usually....Dave Mac transmissions in Coventry.
EDIT 2, the NS inner is possibly this one for the PK6, ive never looked at my one so would need someone to confirm the visual - if its right i'll link you the item on eBay
EDIT 3 (i'll shut up in a minute) or you could buy a brand new shaft complete, a snip at a mere £475 LOL
https://www.ebay.co.uk/itm/Renaultsport ... SwRQlbFbz8
Thanks James and Dave! Want the black mounts for sure. Will try some universal stuff and let the forum know.
The inner boot is ruined on the inside by a cracked gearbox circlip in the past. Its also slightly leaking on the sealing surface. Want to renew it before it snaps and ruins the gearbox while driving without oil. Will remove it in the winter time and search some PK6 cars and see what fits.
