hi
first post so here goes, i have a kangoo 1.9d 2001 with rf type plip key, the van is a non start you turn ignition key and immobiliser light flash's repeatedly, i have replaced the relay box under the bonnet because of the usual fault, but unfortunatley the key's circuit board is stuffed due to water ingress. If i was to get a key and module from another van would it still need reprograming or is it coded to the ecu aswell?
regards jon
p.s. i do have the emergengy code
regards jon
