Installing QS Sports
  • Start date Start date
1. Remove the two clamps on either end of the exhaust (I had to cut mine off with a hacksaw due to the rust).
2. Then loosen the rubber clamps holding each end in place
3. Make sure you have somthing underneath on the floor - Jumper to stop it scratching
4. Carefully twist it from side to side and it should just pop off
