SimonLM
Some of you may be aware of a small problem with my Vee not firing two of the injectors,
The problem originaly was that two of the old injectors were reading short curcit and now I replaced them with new they still will not fire. Ive proved they work by swapping the lead over and it fires the fuel through the new injector.
Ive tried another ECU and this does the same also checked the harness out and all seems to read OK so Im a bit stumpped.
I am wondering if a reset on the computar is needed to clear any safty overides the US injectors may have caused although I have no fault light on the dash.
Anyone have any ideas?
