I don't think I've ever seen such a mess of an MOT history before showing a complete lack of care for the car with years going by with no MOT yet the mileage racking up 20,000 plus amounts meaning it was very likely being driven whilst not being serviced or MOT'd. No MOT at all between March 2012 and July 2014 yet the mileage goes up nearly 20k from 2011 to 2014. could have happened all in the year it was MOT'd but this car has obviously not been laid up but used hard so not likely.
And as for the faults showing up it really is pathetic the lack of maintenance being done on a car like this.
It failed on tyres not once not twice but three different years and one year it failed because the one tyre was through to the cord and 2 others were advisory as on the limit so what did he do? changed only the one tyre that was illegal so on the retest the other two borderline ones were still fitted. What sort of moron does that? One that is then surprised when he ends up in a hedge with 1 new tyre and 3 knackered ones!
£50K HA HA HA HA HA. What a joke.
Poor car deserved better than this.
WV06 GBX
MOT History
Mileage recorded at test, parts failed or had minor problems
Date tested
24 October 2016
Pass
Mileage
92,458 miles
MOT test number
4013 8330 2855
Expiry date
23 October 2017
Advisory notice item(s)
•Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
•Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
•EML on indicating a fault
Date tested
25 September 2015
Pass
Mileage
83,894 miles
MOT test number
9489 0339 0072
Expiry date
24 September 2016
•Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
•Offside Rear Tyre worn close to the legal limit (4.1.E.1)
•Front brake disc worn, pitted or scored, but not seriously weakened wearing thin (3.5.1i)
Date tested
23 September 2015
Fail
Mileage
83,894 miles
MOT test number
3453 6879 5495
Reason(s) for failure
•Offside Front Tyre has ply or cords exposed (4.1.D.1b)
•Windscreen washer provides insufficient washer liquid both (8.2.3)
•Rear Brake pad(s) wearing thin (3.5.1g)
•Nearside Inner Ball joint has slight play tie rod (2.2.B.1f)
Date tested
29 July 2014
Pass
Mileage
73,809 miles
MOT test number
4863 9061 4212
Expiry date
28 July 2015
•Nearside Front Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
Date tested
29 July 2014
Fail
Mileage
73,809 miles
MOT test number
4890 1051 4297
•Windscreen washer provides insufficient washer liquid (8.2.3)
•Offside Rear fog lamp not working (1.3.2b)
•Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
•Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Date tested
30 March 2011
Pass
Mileage
55,256 miles
MOT test number
1283 5998 1020
Expiry date
29 March 2012
•both rear brake discs rusty
•slight movement nearside front rack end
Date tested
3 September 2009
Pass
Mileage
34,863 miles
MOT test number
5715 8664 9225
Expiry date
2 September 2010
Date tested
31 March 2009
Fail
Mileage
26,952 miles
MOT test number
5242 5009 9084
