sparky33
Couldn't find an appropriate place to post this, so this will have to do.
The IACV (idle air control valve) on many of the 16v engines is the same one used on the Vauxhall 1.8 and 2.0 16v ecotec engines, this is worth knowing because, if you need to replace one, they are £160 at Vaux and around £200 at Renault (approx), but you can get them brand new on ebay in the Vauxhall parts section for around £40.
The MAP sensor is also GM, so too is the EGR valve, it would appear a lot of the fueling and emmision control parts are GM badged. (making them cheaper)
Hope this helps.
Hope this helps.
