Help rough running
Bosch man
Ok so all of a sudden feels like its dropped onto 5 cylinders? Sounds terrible lol, over 4000 rpm the engine light flashes? But goes off before that rpm? Easy fix? Clio phase 1
Cheers!
A whole range of info on coils going including where to get replacements can be found here. Personally I've going me replacements from GSF.
Unplug each connector wire on each coil briefly, and the engine note should change. If it doesn't change then that is the duff coil.
..thanks guys i got a new coil from eurocarparts for £30 a valeo one, will fix tommorrow hopefully! [smilie=yay.gif]
a scan will give the correct coil location, i am in nottm if you are anywhere near and have the technology.
How the FU*K do you test the rear bank on a phase 1? If i take the plenum off then i cant start engine whilst i unplug each one?! The front bank are fine :rollseyes:
what i used to do on my phase 1 was make sure the easy 3 are all fine, then unbolt the plenum, swap the 3 easy ones into the ones under the plenum, then bolt the plenum down and check the 3 that were originally under the plenum, which are now in the easy bank
Its a case of checking the front ones first then the back which in the worst case has to come off a couple of times.
Sorted!!!!! Thanks guys front 3 easy, rear, inlet off and all top engine panels, loads of screws! I put the front 3 coilpacks in the rear then put back together. I easy found which one as when i pulled the coilpack on middle rear the top came off! So not an overly difficult job just time consuming. Access is very good with all covers trim off!
