help on an annoying problem.
jimm
Hello all, So i drove my vee ran up to temperature then let her sit running for 10 mins and the temp needle creeps up more than is comfortable.(over half way) Whilst it was running i was checking connections each end of the car , fuses, relays all concerning water pipes to make sure they were warm etc etc . Nothing suspect then the rad fans cut in at about 3/4 on the gauge and the needle come down to 1/2 way again. All is good but i was suprised it had to get this high on the gauge before the fans cut in. Then as i held the window switch down to put the window up the extra strain on the battery made the temp needle move higher. As i came off the switch it returned to normal. Same as putting the heater on full inside the car this also made the needle move higher. Now the battery is correct for the car and only 2 months old so i am just wondering what peoples thoughts were???? Also is there a lower temp sensor availible for the vee and what temp does the water need to be before the fans cut in . thank you
jimm.
