Hi Guys,
Was following the "how to" guide on here re: changing NSF fog light.
However, the MK2 arch liner seems to be completely different to the MK1, one piece for a start.
I've undone the 3 Torx screws along the bottom edge, but can't pull the liner back enough to get access to the screws holding the fog lamp surround in place.
THere's a number of black plastic blanking pieces/fastenings. Some with just a smooth surface, others larger with a hole in the middle.
I presume these are retaining the liner, but how do you remove them?
Ben
Ben
