T
tungsten21
i,ve decided to keep the original air filter setup,with a performance insert,my question is,is it worth buying some proper heatproofing from say demon tweeks and coating the metal bottom part of the housing,also is it worth putting a strip on the underside of the top intercooler between that and the rad????another thing i,ve noticed is if you remove the top air filter hose,the one that goes to the front panel,then look down the round mounting bracket,the headlamp adjuster is totally in the way of the air flow to the filter??anyone else noticed this
