Gearbox oil level ph1
V6-444
Hi All,
I have been looking trough the manuals / information on the forum but i can not find a satisfactory answer.
I found the following:
Ph1 gearbox 2.2L
Ph2 gearbox 2.4L fill to level C on the special dipstick
What should be the correct quantity, and corresponding level mark for the ph1 gearbox?
thanks in advance.
Info I found in the knowledge base.
Phase 1 gearbox
Phase 2 gearbox
i have a gearbox oil dipstick , part number 00 00 167 500 , if car sells ill have one here , will get pic up soon
This dipstick is bullshit. First you have to practice like a hundred times how to insert and position it correctly, which is not easy and when you can't do it in one go, the reading will be false. Additionally you can do it ten times and it won't show the same twice. Better fill up the specified volume. That's faster, easier and also more accurate.
