Fuel Pump - 16V?
more like this ?
more like this ?
Thats a pump and sender combined, the 19 16v has two seperate parts, one for the pump and one for the sender.
The ebay item pictured
does look like the pump used on the 19 16v but its not got the top part which is the seal on the fuel tank where as the one in the pic bazza posted does have the top part required so what you are looking for is a combination of the both.
However, you could buy a walbro 255 pump and replace the standard pump with that, its just a case of splitting the plastic shroud on your one, removing the original pump and replace with the walbro
Walbro Fuel Pump
which is why i said "like this"
:roll:
My bad, I wasn't sure what you were getting at :)
Walbro Fuel Pump
Yeah I know that you can separate the pumps from the casings and seals, as I did when I changed it recently. Problem is it's starting to make horrible noises again. I may well go for the Walbro one, cheers Neo. Sounds like an easy swap, so I'll be upgrading soon :)
