BenR":3bgofg5o said:I'm already working on the v6 fronts and rears, give me a little time and hopefully an off the shelf, plain, simple and cheap solution should be ready.
No PCD issues, although offset might be increased a few mm, so front track will be increased, but not by a large amount, not that it will be detrimental to handling anyway.
Ali":2irekn5l said:BenR":2irekn5l said:I'm already working on the v6 fronts and rears, give me a little time and hopefully an off the shelf, plain, simple and cheap solution should be ready.
"a little time" is a loose term!
Why would the track be increased?!
So who have you been looking/speaking with to?
Suits me fine as it'll make the "over arched" Ph1 look much better.
Oldskoolbaby":dhd67nbp said:Ali":dhd67nbp said:BenR":dhd67nbp said:I'm already working on the v6 fronts and rears, give me a little time and hopefully an off the shelf, plain, simple and cheap solution should be ready.
This is because the disks have a very slighty bigger offset. They will need shimming out for the rotor to sit correctly in the caliper which inturn moves the face of them out slightly. Suits me fine as it'll make the "over arched" Ph1 look much better.
BenR":3v2qh30p said:I'm already working on the v6 fronts and rears, give me a little time and hopefully an off the shelf, plain, simple and cheap solution should be ready.
BenR":339ciqyv said:I'm already working on the v6 fronts and rears, give me a little time and hopefully an off the shelf, plain, simple and cheap solution should be ready.
