front discs on web
I think compbrake did some development work - with Max ? If so, I would imagine then they are in a position to offer the brakes out once the R&D is done - which I expect would be simple bolt patterns and offsets on the bell ...
Our disks should be 32mm in thickness and they are 28mm. I can't see that being a problem but it would be best to keep them at the original 32mm.
According to AP spec sheet for V6 calipers min disc thickness is 30mm, I would say these discs are useless as already under sized before being used.
Steve :(
Steve :(
Sorry, my mistake. It definatly is 30mm. :rollseyes:
