Floaty Front end
Mine are H&R coilovers and on a mk2 (if that makes any difference?)
There is a picture in the gallery somewhere with my settings on it, i will have a look.
There is some more information on this topic also:
LINK
LINK
There were the some discussion in the topic above about the total front toe being +30' or -30'. Which one is the correct?
Does anyone have the Ph1 Vee standard alignment specs handy? I found this earlier:
Front:
Rear:
Are these what most Ph1 vee owners with standard suspension have them set to or is there a sweet-spot set of figures? If you take a look at the front total toe, it is specced to +30'......did Renault revised them later on the Ph1?
My advance apologies for a barrage of questions [smilie=boohoo.gif]
Just an update on sorting out the "floaty front end" situation.
I had the wheel alignment on the Vee checked and adjusted back to factory spec on the weekend. The car originally has a slight pull-to-the-left but that has been fixed by the decent wheel alignment. Haven't got to a straight piece of road that is long enough and straight enough to do 100km/h to see whether the floaty front end has disappear yet.
[smilie=thanks.gif] WONGY for recommending me the place in HK to do the alignment.
