MikeT,
did you say that it was a SADEV unit you have fitted? Do you know if it's the same unit as that fitted in the Spiders? Did the bellhousing need modification?
I don't know what has got Mike but this is not the same bell housing.
- Spider box (and bell) can fit to F family engine ( williams, RS 172,182..., Mégane)
If any-one wants a Sedev sequential gear box with mounts, gear lever, drive shafts, flywheel and paddle clutch, then contact me as i may break my Trophy.
Hey Babrs bonjour!! you also around here? probably see you in Dyon, with my car rebuilt, I don't tell you what has been modded this time.
Hmmm, before you wanna buy an racing sequential gearbox, please take a ride in a car which has one fitted.
After a tour, I suspect about 9 out of 10 don't fancy it anymore, am I right Mike?
Straight cut gears aren't subtile on your eardrums. :shock:
As said the price Mike mentioned is about right, the gearbox is a standard unit from Sadev, you can buy the 400Nm seq6 box from Sadev for 14000 euros at Oreca.
It comes standard with a LSD with limit at your choice.
