ok so long as ecu's stay matched up to the right engine, shouldn't be a problem when tuning then. great.
roadbandit, i still may keep the std manifold yet, just that i assumed larger turbos may have more choice with the non gated housings, depends what i get. the wg was bought by a friend who owes a few favours, an is surplus due to the route he ended up goin, so a freebie. as the sierra downpipe and exhaust will need 'some' tweeking its no extra bother to add the wg port. i already have a modified 172 exhaust manifold to take a turbo so i have a spare one, just got to see whats possible. no real target on bhp, more to get it to drive the way i want.
thanks jo, any info is appreciated, and i'm sure others will benefit. and if its on the forum to see, saves you getting asked twice lol.
regards the parts, wg - see above. the turbo's are the ones i have been looking at. the exhaust will be full 3" not because i'll be making enough power, because i have been offered a full system for a nice price so if i fit it all, then i can sell on my full 21 exhaust. no point having 2 half systems in the garage and puts some cash back into the budget
but do you have any figures that include the exhaust gas temps/pressures on your higher boost set ups? the cheap ic and rad set-up on ebay may not be the best items, but alot better and cheaper than original items and are a closer than universl items, my rad looks like its falling to bits, the top ic rubbers have snapped and its started to rub and the lower one just looks tatty, besides i'll be blowing the caps of at 18psi so will need doin too lol.. i plan to use a 3bar regulator but the 803's cant be enough? i think i maxed them out at 21psi on my volvo engine? think i'm trying 403's first, althought it'll be a bit rough at idle should only see me running them at 80% max then.
ok regards the cam, which is my stumbling block at the moment, due to the budget a secondhand common one will be easier and cheaper than a regrind, but if i have to go that route then it would be nice to know some profiles.
maybe i should have started the thread with what i'm looking to get out of it since you've done most of research. i'm aiming for a std engine, stripped and checked, cleaned and fresh gaskets. cam with adjustable vernier while its in bits. thicker headgasket to allow an increase of boost as same ignition levels. i want it to start making boost about 3200-3500 but not on full boost til nearer 5000, come on cam about 4500 and pull to 6500-7000 max boost at 1.5bar(depending on fueling and detonation), bhp figures will be what they are. so what tried setups are similar?
looking at more widely availiable parts, like cosworths etc, to then be adapted rather than one of custom bits to keep prices down
