i have been following this guide
Clio 16v loom---------------------------------------R5 loom
C7 ---------------------------------------------A1
D4--------------------------------------------- A5
D6--------------------------------------------- A6
D7 ---------------------------------------------A7
B5--------------------------------------------- B2
B-4--------------------------------------------- B-4
C2 ---------------------------------------------B3
B7 ---------------------------------------------B6
D3 ---------------------------------------------B7
----------------------------------------R5 plug behind ashtray (just tap in with cable clamps)
C1 ---------------------------------------------B1
B1 ---------------------------------------------B7
B6--------------------------------------------- C1
smaller white plug B-4------------- B7 drivers footwell (fuel pump)
I actually cut the white GTT fuel pump relay wire & used that to feed the pump from the loom.
Still to look for this but apparently there is a black two pin plug under the dash somewhere, one wire is constant live, the other ign/switched
Main plug B2 & D1/White plug A3 & A7 + pin 6 ecu------------------ Constant live
Main plug A1 & C7 + pin 9 ecu ----------------------------------------------Switched live
Earth-----------------------Pin 2 ecu
but when i get to the last part it says put B2 & D1 from main plug and A3 & A7 from white plug + pin 6 ecu to a constant live, problem is on the phase1 clio loom there is nothing in B2 is this a mistake? on the guide for 19 loom it says A6 instead do i do this? also pin 6 on ecu is a switched earth do i really have to put it to a constant live? it doesnt sound right, hopefully somebody can help.
valverpage1.jpg Photo by 24175mypics2 | Photobucket
